Sienna4po Posted January 12, 2010 Share Posted January 12, 2010 Folks, My 2004 XLE FWD has a parking release issue for a few days, on and off. Need to press the release button to release from P position. Then it was good since then about 2 months. Very wired. Just know that my friend Sienna has similar problem. Just wondering do you folks have this kind of issue. And what is the root course for that? Mechanical or sensor faults....? Thanks Quote Link to comment Share on other sites More sharing options...
Leighcm Posted January 12, 2010 Share Posted January 12, 2010 Folks,My 2004 XLE FWD has a parking release issue for a few days, on and off. Need to press the release button to release from P position. Then it was good since then about 2 months. Very wired. Just know that my friend Sienna has similar problem. Just wondering do you folks have this kind of issue. And what is the root course for that? Mechanical or sensor faults....? Thanks Check to make sure you're pressing firmly on the brake. If you don't have it pressed all the way down, it can cause the same issue. Quote Link to comment Share on other sites More sharing options...
