lowering suspension?
gazoocorolla
hello everyone...i recently aquired a 2005 corrolla...i used to own a 87 celica. anyhow, im interested in finding a suspension for my car preferably one that is affordable and doesnt void my warranty....i have alot of things planned for my new car, but here is where i want to start...your help will be most appreciated...take care...regards from Puerto Rico...
Are you just looking for looks or are you also seeking improved handling.
If you're seeking looks only, A set of sports springs does the job ( And does also bring some improvements to cornering ).
If you want handling, on top of springs you should look into dampers and sway bars too.
Usually this will only affect the warranty on the components that you change but not the remainder of the car.
As has been said, the warranty is only void for the area you replace...
So for example, if you change the suspension, then the warranty will still cover the engine..
Of course, if you get official Toyota parts fitted by a dealer, then that wont void the warranty.. but you'll be paying a premium..
It comes down to whats more important?
