Navigation System Icons...
Howard Woodard
Hi. My wife just bought a 2006 HH Limited with Nav. When reading the manual for the nav system it showed, and described, numerous icons that can be used to change the map display. However, I only see three on hers: (1) single map display, (2) split screen - 2 maps, and (3) compass mode.
Do I have the wrong manual for the car or is there something that I need to do to enable the other icons such as the freeway mode and the upcoming turns display?
Thanks in advance,
Howard
Redmond, WA
Thanks in advance,
Howard
Redmond, WA
Do you have a destination programmed in while you are trying to look at these icons?
