4Runner
Vibration
I have a 2000 4Runner with 178,000 miles. I have had a alot of maintenance lately and still have a vibration coming from the front. The following maintenance has been done. New tires, new brakes, rotors, calipers, u-joints and the tires have been rebalanced. The vibration starts at 60 mph and seems to lessen above 75 mph. Above 60 it happens wether the gas pedal is depressed or not.
Share this post
Link to post
Sounds like something with the wheels...perhaps a bent wheel, or a wheel that needs to be balanced. Or if you have aftermarket wheels, sometimes they need centering rings.
Share this post
Link to post
I just had the tires rebalanced and still the same problem......I'm still guessing. Still have the factory wheels. Thanks for the suggestion.
Share this post
Link to post
Toyota rims are lug centric I believe whereas most other vehicles are hub centric. You should find a shop that has a Hunter Road Force balancer and/or a shop that uses a Haweka adapter for your rims.
http://www.gsp9700.com/pub/features/how.cfm
http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=40
http://www.gadgetonline.com/Vibration.htm
Share this post
Link to post
Loading...
