CelicaL5 Posted February 21, 2009 Share Posted February 21, 2009 ive been looking around on these for alittle while but havent been able to find much for info, is it worth it on a gt to get one? is it going to make a difference? Quote Link to comment Share on other sites More sharing options...
02celicagt-s Posted May 15, 2010 Share Posted May 15, 2010 ive been looking around on these for alittle while but havent been able to find much for info, is it worth it on a gt to get one? is it going to make a difference? These are very bad for your car, it underdrives all of the cars other systems and can lead to very bad consequences. I know on the gt-s it will wear out the oil pump and your engine will not get any oil. If you really want to get one, go with one that is lightweight only, not an underdrive. Quote Link to comment Share on other sites More sharing options...
jonsgts02 Posted October 6, 2010 Share Posted October 6, 2010 the only pulley that is worth upgrading would be the crank pulley. it is the same diameter so nothing would be thrown off, it is just lighter in weight having less parasitic loss of engine output. check out unorthodox racing. Quote Link to comment Share on other sites More sharing options...
GTrd Posted November 4, 2010 Share Posted November 4, 2010 I just bought an unorthodox pulley (alt and crank) and works pretty well. Quote Link to comment Share on other sites More sharing options...
seminoleredneck Posted April 24, 2011 Share Posted April 24, 2011 I know this topic has not been touched in a while, but I have put underdrive pulley systems on numerous cars and NO car that I have put it has had adverse effects, especially the oiling system. Unless Toyota did something really unusual and made the oil pump belt driven rather than crank driven on the GT-S, the underdrive pulleys will NOT effect the oil being dispersed throughout the engine - the crank speed will remain the same with or without the pulleys, hence, the oil pump delivers the same amount of oil regardless. Quote Link to comment Share on other sites More sharing options...
