bikemail Posted December 12, 2008 Share Posted December 12, 2008 Greetings, This is my first post. My 1994 Previa van has about 150000 miles. Over the past few months the blower has sometimes not worked. To get it working we would flip the inside/outside air lever and it would start up. A few days ago it stopped working altogether. I opened the dash and it appears that the inside/outside air lever is not connect to any electrical switch. It must have been voodoo or some other indirect relationship such as the vibration/thump of the lever. In any case, I wonder if anyone has any ideas. It doesn't seem like a fuse or relay because it was first intermittent. I don't see how the inside/outside air lever could have anything to do with it, but it seemed to have an affect probably 100 times. Thanks in advance for any ideas... -Greg. -Dayton Ohio, USA. Quote Link to comment Share on other sites More sharing options...
bikemail Posted December 14, 2008 Author Share Posted December 14, 2008 Additional information... the rear defog is also inop. I wonder if it'ss on the same circuit with the blower? -Greg. Quote Link to comment Share on other sites More sharing options...
BitBrush Posted February 4, 2009 Share Posted February 4, 2009 ...A few days ago it stopped working altogether. I opened the dash and it appears that the inside/outside air lever is not connect to any electrical switch. It must have been voodoo or some other indirect relationship such as the vibration/thump of the lever...It doesn't seem like a fuse or relay because it was first intermittent....I don't see how the inside/outside air lever could have anything to do with it, but it seemed to have an affect probably 100 times. Same exact thing as mine...including the inside/outside air flap. Except my "thumping" wasn't as fruitful. Hitting a chuck hole the other day brought it back to life though...too bad I was in sight of the house on the way home....but it didn't come back on later. I'm thinking an intermittent connection somewhere between the blower, the relay and the ground or 12vdc. Like yours, the relay and switch are working fine. Swapped the headlight relay for the blower and the lights still worked! The relay clicks as expected when the switch is moved. I hope that someone takes pity on us and responds with an easy resolution. Don't really want to go the route of removing most of the obstacles between the air intake and the blower under the hood. Its going to be single digits to teens tomorrow. I have to keep a window cracked to get enough airflow over the windshield or my feet. I'll shoot back a response if I come across a "fix." David Greenwood IN 1994 - 265,000+ miles and praising God! Quote Link to comment Share on other sites More sharing options...
BitBrush Posted February 15, 2009 Share Posted February 15, 2009 OK...my bad news. Had a warm day and decided I'd had it with frosty or foggy windshields. After taking off a nearly endless number of nuts and screws and under hood parts I finally got to the resister and tested it. It wasn't the resistor! Sadly, when I opened the motor, I found that the brushes have disintegrated into powder and nearly chewed all the way through the commutator. Explaines the black powder collecting around my vents. I'm looking at anywhere from $75-$125 for a new replacement motor or $25 for a kit to replace the brushes (the same price as a replacement resistor) and I haven't yet priced any blowers at the salvage yard where they have a couple of wrecks sitting. Need to pick-up some rear lifter arms as well if I go there. Hope this helps in your quest. David Quote Link to comment Share on other sites More sharing options...
