almc2242 Posted May 14, 2008 Share Posted May 14, 2008 I have a lighty modified 1997 Toyota RAV4 (yes, a RAV4) Here are the mods. RAV4orce, Magnaflow Muffler 2.25, and Borla Tip, Pace Setter Header, DEI Thermo Wrap, Random Performance Cat Converter, TRD Thermostat, TRD Radiator Cap, Addco Rear Anti-Sway Bar, K&N Apollo Intake filter, TRD Quick Shift, RAV4.1L Front Tower Brace, H&R Springs, Bilstein SPORT Shocks, 2003 Rear Tire Hard Cover, HID Hi and Low beams, Clear front Markers, Rear Reverse Lamps and rear brake lamp, Bomex Front Spoiler, 1998 Rear Taillight, and TRD front Anti-Sway Bar, Yokohama AVID V4s 235/60/16, All Energy Suspension Poly Bushings, Kenwood Receiver, Alpine 40X4 RMS AMP, Infinity Speakers, Infinity Basslink Woofer (200WATTS). Power Slot Slotted Front Disc Brakes, Magnum Hi-Performance Stainless Steel Brake Lines, Twin Derale Engine and Gear Box Oil Cooler, Next Level Performance Tri-Phase module, Front and Rear Spacers 1.25, Nology Spark Plugs and Wires, MSD 6A, MSD Tach Adapter, MSD Blaster SS Coil. Performance Oil Pump, bought, Performance Aluminum Performance Water Pump, bought. Pivot Ground Kit, Pivot Raizin Electrical Stabilizer, DEI Exhaust Rap on Header and 2.25" Pipe. Scan Gauge II, Helix Power Tower Spacer Plate, Grounded Muffler among others. Please click on link and using headphones. Can you tell me what is this rattling sound. http://www.youtube.com/watch?v=uPBhjm9fWPE Quote Link to comment Share on other sites More sharing options...
Leighcm Posted May 14, 2008 Share Posted May 14, 2008 Can't tell from the video... That's an impressive list of mods though...even more so because it's a Rav4. Wow! How much faster is it, anyway? Quote Link to comment Share on other sites More sharing options...
XR2003 Posted May 14, 2008 Share Posted May 14, 2008 Nice mods on the RAV4. That sound you speak of might be the popping sound from the aftermarket exhaust. Since you have a better flow out from the engine, when you take your foot off the accelerator a popping sound may occur. This is normal. Quote Link to comment Share on other sites More sharing options...
almc2242 Posted May 14, 2008 Author Share Posted May 14, 2008 Can't tell from the video...That's an impressive list of mods though...even more so because it's a Rav4. Wow! How much faster is it, anyway? I really don't know, it always runs out of real estate before the Scan Gauge II can give me a final reading. Quote Link to comment Share on other sites More sharing options...
almc2242 Posted May 14, 2008 Author Share Posted May 14, 2008 Nice mods on the RAV4. That sound you speak of might be the popping sound from the aftermarket exhaust. Since you have a better flow out from the engine, when you take your foot off the accelerator a popping sound may occur. This is normal. It does it only when I'm accelerating. Like in low torque, once it picks up speed, it doesn't do it at all. But the way, all the mods are posted on http://www.rav4world.com . Look for mensajero, that's me. Quote Link to comment Share on other sites More sharing options...
