Watchdog Posted December 27, 2022 Share Posted December 27, 2022 Hi all, confused about this. 1982 Toy pickup 22 r. Doesn't seem to be charging. Battery good, maintains a charge after slow charging. New alternator. Charge light comes on as supposed to before turning key, goes off after engine starts. Doesn't come back on when running. BUT when running the battery discharges. any ideas what to look at? Have checked battery connections, tight. Checked belt , about 1/2 in deflection. What else should I look into? Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted December 30, 2022 Share Posted December 30, 2022 Check the chassis and engine earth straps/leads as if one of these is broken or corroded then this could cause the symptoms you describe Quote Link to comment Share on other sites More sharing options...
