surge Posted October 2, 2007 Share Posted October 2, 2007 I have a Gen 3 OEM Denso Nav unit in my 03 Lexus which is the same unit used in the 03 Toyota's My unit comes up in Japanese with the following text in English. CAUTION Error; System unable to access the program. Incorrect program disk. Please insert proper disk. I have more information as well as a picture of what my NAV unit shows at http://lexus-toyota-nav-trouble.blogspot.com/ Has anyone seen and fixed this? thanks. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted October 2, 2007 Share Posted October 2, 2007 What happened leading up to this issue? Did you do something to the disc? Quote Link to comment Share on other sites More sharing options...
surge Posted October 3, 2007 Author Share Posted October 3, 2007 What happened leading up to this issue? Did you do something to the disc? There's a way to bypass the lockout while driving and I've done it plenty of times without issue. Unfortunately, there are some other buttons on the screen that should not be touched. One of them changes the program that the NAV runs. I inadvertently changed it to read the Japanese program so now it is looking for the Japanese LOADING.KWI file. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted October 3, 2007 Share Posted October 3, 2007 So you need to go back into the override, and change the language back, right? ...or can't you get that far? Quote Link to comment Share on other sites More sharing options...
surge Posted October 4, 2007 Author Share Posted October 4, 2007 So you need to go back into the override, and change the language back, right? ...or can't you get that far? That's correct.. now that it is looking for a Japanese disk, it won't go anywhere. Check the post I have linked and you'll see the screen that it stops at. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted October 4, 2007 Share Posted October 4, 2007 How long did you disconnect the battery for? Did you give it at least 5-10 minutes? Quote Link to comment Share on other sites More sharing options...
