Latest Posts
Showing topics posted in for the last 365 days.
- Last week
I purchased this car—a mid-life crisis, if you will—in 1998. It has been a blast to drive, especially with the top down on warm summer evenings. I love that the mileage is low: 61,300. Previously, I owned and drove a 1983 Tercel 4WD for 30+ years, and recently gifted my 2005 Matrix with 139,000+ miles. The Celica is my baby (next to my 2013 Lexus 350ES), and I have kept it up over the years with new paint and upholstery. Admittedly, it is hard finding parts for minor repairs. I am a die-hard Toyota fan!
I am going to replace the lens on the driver side outer tail light on my 2013 Avalon. I haven't been able to find a video of this. Can someone tell me how this is do? I believe that removing the black plastic piece is the first step, but not sure how to remove it and don't want to break it. If it prys off, where is the best place to pry on it? Do I have to pull away the trunk liner to get the lens off?
I have a 01 sienna can I put a 09 rack and pinion in it? I figure I will have to use the originals tie rods but will the rack itself interchange?
Remote Key for Venza
albertaa replied to Johnog's topic in New Members Area - Just signed up? Come and say Hi!
just purchased a 2024 Venza same thing only one key. they do come with 2 but due to chip constraints the dealer will inform me when they come in to pick up and program the key btw the salesman as been waiting since Jan for a key to is highlander. surely you haven't been waiting since last year?? - Earlier
I have the exact same issue. Never know when it will happen. Engine cranks just fine, but won't start. Then it will. Jumping helped once, then it didn't. If you get an answer, put it out there... I cleaned the MAF as I saw in another thread, and it helped for a short while, but still the same issue exists.
I just got a new 2024 trd off road premium , what part do we need to stock up. Since it is an out going model . Thanks Sam
I just purchased a 2000 Camry XLE V6 with 41K miles. Can anyone on here recommend a shop in the Annapolis area where I could take it to get a full workup?
Just purchased a 2000 Camry XLE V6 with 41K miles. Anyone on here know of a good auto shop in the Annapolis area where I could take it to get a full workup on it?
The extra set of wires goes to the subwoofer. It has 2 positives and negatives cause its a dual voice coil.
I hit a pothole on the highway and my right rear tire started making a very loud rubbing noise. I pulled over and found some sort of plastic bracket came from somewhere in front of that rear tire and pressed against the tire tread. The bracket is sort of shaped like a capital T with a hole in each end of the cross piece at the top. It’s about 4” wide at the top. I tried to break it off and could not. Therefore I twisted it down and towards the front just outside of the wheel well. Does anyone know what this part is? I’ve looked at many parts diagrams and can’t find it. Thank you
Hi I am on the search of trying to buy an AE86 for under 10k, with full interior, and manual in my area if you tick all of these boxes or come just a bit above 10k then respond to this post
Hi I have been looking for an AE86 that run under 10k and found some around my area I want to know more about common problems with AE86's and what to expect when owning an AE86.
Do you have the owner's manual? You can download one here: https://www.toyota.com/owners/warranty-owners-manuals/ This button cycles thru the odometer functions as I described earlier.
Hello, bought a 2020 corolla le a few years back, was used when i got it. But just recently started saying the device isnt supported while still working. And flashing the sos lights red and green. Doing some research i guess the dcm module is to blame but cant find much more. Tried unplugging the positive on the battery for about 30 minutes but will try both terminals, and longer. Heard theres a battery that can go bad but not sure how easy it is to get too. Also heard a service bulletin for a similar issue where it’s just needing an update, and lastly ive heard from many to disable the thing with the fuse but my fiance uses the microphone feature. Where should i go from here? About to disable it and jump the pins at this point.
Costco, the warehouse club known for bulk bargains, also offers members a perk at the pump: discounted gas. But how do these gas prices compare to what you might pay for your Toyota, and is a Costco membership worth it for gas savings alone? Costco Gas: Lower Prices, Higher Membership Costco gas stations are notorious for their long lines, and for good reason. They consistently offer some of the cheapest gas prices around. However, there's a catch: you need a Costco membership to fill up. Memberships start around $60 a year, so the savings need to outweigh the cost to make it worthwhile. Finding current Costco gas price can be tricky, as they aren't widely advertised. Some resources like GasBuddy offer crowdsourced price information, but the most surefire way is to check the gas station itself upon arrival. Fuel Efficiency Matters for Toyota Drivers Toyota vehicles are known for their reliability and fuel efficiency. This is important because even with discounted gas, maximizing your miles per gallon (MPG) saves the most money in the long run. Here's a breakdown: A typical Toyota Camry might achieve 30 MPG on the highway. At a national average gas price of $3.70 (as of July 2023), driving long distances can get expensive. Even a small discount at Costco, say $0.10 per gallon, can add up over time. However, if you mostly do short trips around town, the gas savings might be negligible. The Verdict: Crunch the Numbers So, is a Costco membership worth it for gas savings with your Toyota? It depends. Here's what to consider: How often you buy gas: Frequent drivers benefit more from price savings. Your typical driving distance: Highway miles make fuel efficiency more crucial. Costco membership benefits: Gas is just one perk. Do the other benefits justify the cost? If you're a highway warrior who fills up frequently, a Costco membership could pay for itself in gas savings. However, for casual drivers with Toyotas known for fuel efficiency, the break-even point might be higher. The Final Thought Costco gas can be a great way to save on fuel for your Toyota, but it's not a one-size-fits-all solution. Consider your driving habits and membership value before making a decision. pen_spark tuneshare more_vert
I have a humming noise coming from the rear of my 17 Highlander when speed gets to 55 to 60 mph. Has anyone else have this problem?
Old guy but new to this forum. I've owned a few Toyotas in my time (4 Prius, 1 Tacoma) now I have a 24 Camry LE Hybrid. I REALLY like the mpg even though it's a little hard for us 70 year olds to get in and out of. The MOST annoying thing for us was the seat belt buzzer(gong). We do use our seat belts but there are times when I will start driving before the wife gets her belt buckled (fidling with her purse, sunglasses,kleenex,etc) and I found it very annoying. I asked the Toyota service dept to shut it off and was told it couldn't be done. IT CAN BE. I follow a great Toyota mechanic on Youtube (THE CAR CARE NUT) and he showed me it can be done with the right scan tool (and should be able to be done with the Toyota scan tool). It just depends on how much $ you want to spend to get rid of the noise. The scan tool is currently around $550. It's an Xtool D8. Please watch his video on Youtube to see how it's done if you're interested. I bought the D8BT (bluetooth version) and had to hunt for the way to do it. I have seen the D8 on ebay for almost $100 less. Returns are very easy on Amazon. I now don't have to listen to that noise.
https://youtu.be/aTA1DUmtIyE?si=018sF6KmR1jBdCkL Hi! My name is Luke. I bought a 2001 Camry a few months ago with the intentions of turning it into a daily driver. The guy I bought it off of "rebuilt the motor", which he might've, he seemed genuine and the inside looks pretty good. But that being said there could still be something wrong. It's a 2001 Toyota Camry with the 2.2 in it. Stick shift too. I added a video link so if anybody recognizes the noise they might be able to help, thank you!
Just wanted to say hi and I’m eager to start mods for my 24 Taco TRD Sport Premium. thanks for the add Scott
Ok, so I'm new to this forum. I have a 2024 Corolla LE and just recently had 20" wheels installed along with 245/35r20 TOYO's. I am still getting vibrating in the seats and floorboard even after rechecking the balancing 6 times and road force testing. Anyone else had this issue? Maybe I need hub rings even though the wheels are lug centric?
New Member
Toyota Owners Club replied to huffman's topic in New Members Area - Just signed up? Come and say Hi!
Hi ....welcome to the Club Good to have you onboard!
