Help - Search - Members - Calendar
Full Version: Paseo untamed - can someone help?
Toyota Owners Club - USA > Toyota Car Models & Hybrids > Other Toyota Models
wadeblues
I just bought this Paseo. The idle fluctuates when cold between 1200-2000 rpms. Once the car is warm, it seems to quiet down, but still idles between 1000 - 1200 rpms. It will also lurch when at a stoplight - more pronounced when the a/c is on, but still when not on.
When cold, the idle sounds like it is gasping for air. It is a regular pattern (up, down, up, down, up, down).
There is a (fakey) K+N air filter and enlarged exhaust, but I don't know if any other engine modifications were done. It is not a cold air intake, just a larger tube basically. Could this be causing the problem, the air intake or the exhaust, or both? If not, I have read maybe the battery connections, fuel filter, air intake leak, or vacuum problem. No problem on the first two, but I don't know how to check the latter two problems.
Oh, also the brakes seem to be not grabbing well, and they were just serviced. Does this indicate a vacuum problem on this car?
Can anyone help? Thanks, Wade
fidgits
I would say it sounds like this induction/filter kit wasnt designed for your engine, and could be causing the problem..
although, it might be worth trying to reset the ECU first?
fidgits
I thought I would reply on the forums, just incase anyone else has similar questions...
To reset the ECU, best bet is to disconnect the battery, then leave a couple of minutes - press the brake pedal to get rid of any charge in the system, and that should have done it.
fidgits
QUOTE (wadeblues)
I don't know if this helps or not, but the speedometer reading is pulled up from an increase in rpms, and the brakes are very tempermental. Does this all indicate a vacuum problem?
Wade
What do you mean by the speedo statement? is that different.
I would not say the brakes are related to the intake at all..
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
