2000 avalon
tomv
Sounds like an ignition timing "run on" problem, which is typically the problem when an engine continues and/or restarts after turning off the ignition. Ignition timing should be constantly "automagically" adjusted by the engine control circuitry, but perhaps yours needs to be evaluated by Toyota service.
  • 4 months later...
does anyone know what year radio's are combatable with a 2000 Avalon I would like to put a newer year radio that has a Aux plug
for my daughter phone I'm have to make sure the wiring harness is the same
