bar046 Posted December 30, 2013 Share Posted December 30, 2013 I have a 2008 Tundra (bought new) that has just recently developed a problem with the right side headlamp. I thought one of my bulbs had burned out and I replaced them. When the lights are on low-beam the bulbs barely light. If I indicate a right turn-signal while they are on low-beam it blinks normally. However, when I switch to hig-beam, none the the lights work and the turn signal fast blinks like an indicator bulb is burned out. The left side works as per normal. Anybody run into this type of problem? This same vehicle blows the 25amp EFI fuze approximately every six months for no reason. Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted January 2, 2014 Share Posted January 2, 2014 Sounds like it could be a bad ground or something but I'm only taking a guess at this? Quote Link to comment Share on other sites More sharing options...
