kzelle94 Posted January 11, 2013 Share Posted January 11, 2013 hi can anyone help me out with a major electrical problem i cant figure out what to do. so far i checked my battery and my ground wire and all my fuses. starters fine. lights are going nuts (dash, clock, hazards) and my car wont even turn over. only only things that dont work at all are my radio and sometimes my antenna. but everything else works fine. (heat, lights, brake lights, reverse lights, blinkers, wipers, sprayers, locks, windows, convertible top, mirrors, horn, interior lights, etc...) hazards work when i press them on but when i turn them off they keep going. Quote Link to comment Share on other sites More sharing options...
Steve Posted January 11, 2013 Share Posted January 11, 2013 Have you recently had wet weather.. lots of rain? The issue could be water someowhere causing the problem Quote Link to comment Share on other sites More sharing options...
Alex Ramos Posted April 22, 2013 Share Posted April 22, 2013 im not expert but seems like one of you fuse boxes are in bad shape. check first the one is next to the battery, but not only on top check under the fuses(were the cables are connected), if you see worn or burn cables there is you problem. check the ones are touching and replace them. if you dont find anything there maybe you wanna look on the driver side kick pane there is a lot of cables, wile you check them be very careful to nt move them so much. i very sure that the problem will be on the fuse box next to the battery,also chech the cable that go from the battery to the starter and i recomend swap it for one that is '0 gauge' you can find this at the audio store.any way i hope this help's. Quote Link to comment Share on other sites More sharing options...
