Dans06Tacoma Posted June 18, 2008 Share Posted June 18, 2008 Hello everyone! I've recently read about hypermilling or hypermiler's -- which means one coasts in Neutral (auto or manual) whilst driving say downhill, then re-engage the gearbox, (I have an automatic)...when a flat plain comes up - or a gradual climb or hill. I've had good success thus far - and haven't any gear noise, all smooth transitions. Here's my question: Since Reverse in my automatic, is right above neutral, what happens if I by mistake, slip it into reverse gear? Obviously one of two things will happen...nothing as there's a safeguard in place dis-allowing the gearbox from engaging into reverse, or the gearbox engages into reverse and I lose the gearbox, as the truck flips and I die! Hope not... :o :!: Anyone know? Today - in fact, I slipped it into reverse for a moment and nothing happened, (for about 1 second)... I'm compelled to try this, as I read an article in the newspaper about it, as it really helps conserve fuel. Thanks. Quote Link to comment Share on other sites More sharing options...
XR2003 Posted June 18, 2008 Share Posted June 18, 2008 Hello everyone! I've recently read about hypermilling or hypermiler's -- which means one coasts in Neutral (auto or manual) whilst driving say downhill, then re-engage the gearbox, (I have an automatic)...when a flat plain comes up - or a gradual climb or hill. I've had good success thus far - and haven't any gear noise, all smooth transitions. Here's my question: Since Reverse in my automatic, is right above neutral, what happens if I by mistake, slip it into reverse gear? Obviously one of two things will happen...nothing as there's a safeguard in place dis-allowing the gearbox from engaging into reverse, or the gearbox engages into reverse and I lose the gearbox, as the truck flips and I die! Hope not... :o :!: Anyone know? Today - in fact, I slipped it into reverse for a moment and nothing happened, (for about 1 second)... I'm compelled to try this, as I read an article in the newspaper about it, as it really helps conserve fuel. Thanks. a new transmission would be needed if you do that again for quite some time. . . as for hypermiling - increase the air pressure in your tires for a little better fuel mileage. also slow to a light - then as it turns green - smoothly accelerate. ;) Quote Link to comment Share on other sites More sharing options...
Leighcm Posted June 18, 2008 Share Posted June 18, 2008 It's the same basic rules for everything, gas, hybrid, diesel to maximize mileage...common sense, mostly. Here's what Toyota has to say: http://www.toyota.com/about/our_commitment...ze_mileage.html Maximize Your Mileage Here are some quick and easy tips to get the most out of any vehicle: Plan ahead-combine several short trips in order to minimize cold engine starts. Accelerate at a moderate pace Monitor highway speed. Fuel economy suffers at about 65 mph and plummets above 70. Regularly check and maintain proper tire pressure. Don't carry unnecessary loads. Excess weight reduces fuel economy. Use the air conditioner and defroster only as needed; both reduce fuel economy. Hybrid drivers can take these steps to maximize mileage, too: Monitor the flow of traffic to plan your moves well ahead. If traffic is slowing, use moderate early braking or coasting instead of hard braking. In slow-and-go traffic, accelerate to the desired speed, then lift off the throttle to maintain that speed under electric power. You may be able to sustain speeds in the 20-40 mph range without engaging the gasoline engine. Quote Link to comment Share on other sites More sharing options...
humanoid Posted June 19, 2008 Share Posted June 19, 2008 Here's a 100+ tips for hypermiling: http://ecomodder.com/forum/EM-hypermiling-...-ecodriving.php Quote Link to comment Share on other sites More sharing options...
